Tip: Your BIOS most likely supports creating and saving screenshots. Look in the legend which key to press, although it often is F12. You need to have some drive with FAT16 or FAT32 file-system to save the image. The file can then be converted to PNG (or JPG) to make it much smaller in size.i make a picture from it (hope i can get it in good quality for u)
Ok thanks, i will look for itTip: Your BIOS most likely supports creating and saving screenshots. Look in the legend which key to press, although it often is F12. You need to have some drive with FAT16 or FAT32 file-system to save the image.
See also
Creating a screenshot within the BIOS – How it works
If you want to take a screenshot within the BIOS of your computer, laptop or netbook, you have to press the following key. More information is summed up here:www.solvemix.com
How to Take A Screenshot in Your Motherboard BIOS | UnbxTech
www.unbxtech.com
This is much better than a blurry, over- or underexposed picture taken with a camera or a smartphone...
Regards
Dalai
sounds very good, i had buying this Board because it was so cheap (200€ new, normally like 260€)Interesting - the mainboard sensor layout is very similar to some ASRock Z590 series![]()
