BlueBase
Hi Guys,
I am planning to get a water temperature sensor for my first water cooled build.
Either
Alphacool Eiszapfen temperature sensor G1/4 IG/IG mit AG Adapter - deep black.
or
Bitspower G1/4" Black Sparkle Temperature Sensor Stop Fitting
Do I need a particular software to use this?
I would like to use it with common monitoring software like HWinfo if that possible.
Im guessing...
After integrating sensor into loop, plugging the 2-pin connector into motherboard and Turning on the PC,
Windows should then detect the device and install the driver?
After all that, the Temperature Sensor should appear in HWinfo software?
TIA!!!
Either
SEN Alphacool Eiszapfen temperature sensor G1/4 IG/IG with AG adapter - Deep Black
Alphacool Eiszapfen temperature sensor! Stay in control of your water cooling! You decide how warm your system gets!
shop.alphacool.com
or
Im guessing...
TIA!!!
