yes, but it also worked just fine with all 1x row checked. It worked with the 7-f half too, but i had that weird no video at windows login bug. it owrked with 4,2,1 too(as in C,D,E,F).Thanks! So with only the box for 1F checked all works OK?
The cool thing is that when using 1x, there is no greyout. All values are perfectly read with no issues. I wonder if this trick would fix the same greyout problems on my old Z390, as well as other people's similar greyout issue on the vrm sensor. Searching for a solution on my greyout problem, i have found a lot of threads with the same vrm sensor wrong or straight greyed out problems.Unfortunately it's not possible to know what's there. I have already contacted GIGABYTE for a clarification and waiting for their response.
It seems to be replacing the dbg file every time i close the app. Well, this slower mode actually fixes every issue I have and i don't have to tweak anything. I don't even have that no video at boot problem I had with 1f checked. Is there something that I can tweak so I can disable debug mode but preserve this slow mode? Polling period doesn't seem to be changed with debug mode.Could be some timing marginality as Debug Mode is slower. I don't recommend to run with this enabled for normal use as it dumps data to disk and that file can grow pretty large over time.
