0c Temp Reading, Fixed with MC 0x1F
ezflma
@Martin (and anyone else), it looks like Intel finally corrected the 0c temp sensor bug with microcode 0x1F. I'm running an MSI Z690 Edge WiFi DDR4 with an i9-12900K. This microcode revision was added to my MB's support site on MSI with the main feature of enabling i9-12900KS support.
I let HWInfo run all day, and no 0c reports whatsoever.
mnemonic
I can confirm that on 11th gen the 0° core problem seems to have been fixed as wel with a new microcode version 53. Been running now for over 4 hours without any 0° glitches.
Lafrance
Thank you! I understand correctly that in order to update the microcode, you need to wait for a BIOS update from the motherboard manufacturer?
Basically yes, but the operating system is also able to update the microcode.
