Alieware Aurora R8 Launch Fan Control
schrappe
Running HWiNFO on Aurora R8, it launches automatically with the Sensors window minimized. However, Fan Control does not launch automatically even though I have added OpenFanCrtlMin=1 under Settings in HWiNFO64.INI. I have to manually click on the icon and open it to ensure fans are correctly controlled. Just wondering if there is another parameter I need to configure. I am running version 6.06-3770
Many thanks!
Bruno
There should be no other requirement. Are you sure you have put the right entry into the INI file?
It should be OpenFanCtrlMin not OpenFanCrtlMin as you wrote above..
