Aspire V5-552G Fan Control not findable
Nachas0n
Hey Guys, i bought several months ago an Acer Aspire V5 and it uses 64-Bit Windows 8.
The laptop ist pretty good at gaming and i should have 2 fans to control, but the laptop shuts down every time i play longer then 20 min, it is getting to hot, so i downloaded HWiNFO to work on this problem by regulating the fans, the problem is, i have no button in the sensor screen, i mean nothing at all, sure i can push "Reset Value" etc. and i can see my Fans but i dont have the ability to adjust them... any help?
Fan control is not supported on that laptop. Only very few models are supported.
If you think the laptop has a serious issue with thermal management, the best is to contact the vendor.
