Asus X670e-i Chipset Temp not showing up
DRGN7403
Is the ASUS X670e-i board fully supported? "ASUS ROG STRIX X670E-I GAMING WIFI (AMD Chipset)" shows up as a sensor category, but no temp sensor is displayed or chipset temp.
this is what shows up only
If the Chipset temperature is not shown then it's because the BIOS didn't properly set up the chipset for temperature monitoring.
Try to upgrade the BIOS.
Hmm, then I think the BIOS doesn't enable chipset monitoring for your board. You might try to contact ASUS support to add/fix this.
