Bug regarding hiding sensors and changing the layout
Hi, @Martin .
I have a bug to report in regard to hiding sensors and changing the sensor layout in the program. First, I want to tell that this bug I have found since version 7.69.53.40 and 7.71.5351. I have tested both versions in different systems (all of them recently built and updated, one with Win11 Pro and the other one with Win10 Pro. I tried afterwards using version 7.69.5330 (which is the same one I'm using in my PC) but to no avail :(
The program starts normally, but when you start deactivating sensors and changing those sensors layout, all goes awry (as you can see in the included screen caps) and I can only return to the original layout using the corresponding option inside the menu. This happens also when I deactivate some sensors and choose to hide them. I don't know what is happening
First update to the latest version 7.72.
Then do a complete "Reset Preferences" in main settings of HWiNFO to remove any erratic items that might have occurred in previous versions.
