Clevo N750HU fan speed
axel
Hi all,
I've just discovered this magnificent piece of software.
Any idea whether the laptop Clevo N750HU with chip "ITE IT8587E" will one day be supported for fan monitoring(only read rpm speed)?
I can provide more info but I don't know where to start...
Thank you very much!
axel
[font=Roboto,]Enclosed you will find the report. [/font]
[font=Roboto,]Any help greatly appreciated.[/font]
  • hwinfo.HTM
I will also need the EC dump made using RW-Everything, best when fans are off and all on.
axel
My model features a hotkey that turns the fans on max so i'm sure it's max rpm speed. How accurate is the rpm speed in HWiNFO64? Is it base on voltage control?
  • EC6662rpm0.rw.txt
  • EC6662maxspeed.rw.txt
How many fans are there? I can see only one fan speed reported.
I'm not sure about accuracy, fan speed is monitored by proprietary Embedded Controller.
axel
Ok, i'll be waiting for new build. I need this to diagnose the other program. Thank you very much!
axel
[font=arial, sans-serif][font=arial, sans-serif]I would like to notify that everything is ok. HWiNFO have started showing the fan speed. T[font=arial, sans-serif]hank you very much for [font=Tahoma, Verdana, Arial, sans-serif]your [/font]help.[/font][/font][/font]
