Hello. I have couple of questions. Im really curious about this.
1- Why cpu pll oc voltage affects cpu temps weirdly. People generally says it skews temp readings. I checked thermal throttling and performance limit reasons tab on the hwinfo. Its always throttling at 99C doesnt matter cpu pll oc voltage. But 1.2v pll oc gives much lower temps than 1.3v pll oc. Mobo automatically sets 1.3v if i overclock or enable xmp feature of my ram. However im using default 1.2v always.
Cpu pll oc voltage doesnt affects any stability.
Prime 95 1.17v: hottest core 72C
Prime 95 1.2v: hottest core 75C
Prime 95 1.25v: hottest core 80C
Prime 95 1.3v: hottest core 85C
Looks like temp reading offset but some cores gains more temps than others. No package power difference. Which temp is true ? 1.2v 98C works without throttling. So 1.2v should be true reading ?
Mobo: Msi z270 tomahawk arctic
Cpu: 7700k
Gpu: Vega 64 LC
2- Also i have 2 cpu package readings. One of them is on the 7700k dts tab, other one 7700k enhanced tab. Both reports little different temps.
5min recording:
Cpu pack dts: min35 max71 avg39
Cpu pack enhanced: min35 max72 avg39 (both readings averaging same temp after couple of minute but they are always reporting different temps at the same time)
Peci: min35 max71 avg 38.6
Core max: min33 max71 avg37
Delay 0 ms.
What is core max temp btw. Which one is more reliable. I guess individual core temps more reliable but i want just one number.
3- Do you have any idea about Vega hotspot temp ? After repasting and repadding my temps improved but hotspot temp worse now.
4- Watt readings are reliable ? Cpu package power for cpu and gpu core power, gpu memory power, gpu chip power for gpu. Also i have Corsair rm1000i so i can see power consumption with hwinfo. How much reliable are these readings ? Cpu and gpu readings showing total 15-20w consumption at idle but my psu readings 60W at idle. 50-55w coming from 12v rail. 10W from 5v and 3.3v rails.
Cpu: 7700k
Gpu: Vega 64 LC
5min recording:
Delay 0 ms.
