Hey HWINFO forum,
So I'm not sure when this started, and I dont post on forums often so ill try to make this easy to understand. So a few days ago I opened HWINFO(v6.26) after not using it for a while just to check CPU temps after gaming, and I noticed when idle, literally nothing open in the background, my CPU Usages fluctuate between the same percentages constantly (0.6%, 0.7%, 1.5%, 2.2%). Sometimes the cores will drop down to 0% but then it goes right back to fluctuating between those 4 percentages. Ive been trying to pin point whats causing it through Task Manager monitoring for a few days now, but nothing seems to be the culprit. I even tried a full system restore, deleteing everything off my pc, resetting overclock and downloaded HWINFO before anything else, only to find the same fluctuations happening. I have been using HWINFO v6.26 since I got this pc 2 years ago, and back then, when i was monitoring my pc all the time, the CPU Usages would drop to 0% when everything was closed and im not at the PC. I noticed this issue and thought maybe if I updated to a later version(v7.07) it would fix the problem but it still persist. Im at a loss here and could really use some help.
A video down below shows the fluctuations (Sorry for the god awful quality, hopefully you can see the usage numbers):
Specs:
Z390 AORUS ELITE MoBo
Intel i7 9700k Overclocked to 4.8MHz
Gigabyte RTX 2080 Super
16gb RAM
Windows 10 Home Version 21H1 (Latest Version)
Avast Antivirus
COMODO Firewall
Specs:
16gb RAM
Avast Antivirus
COMODO Firewall
