ddr4 thermal sensor issues
bitxan
[font=arial,sans-serif]Hi, I have this ram but it does not read the temperature, of course it has a sensor, does it have a solution?
Thank you.[/font]
Module Manufacturer:                                                            Galaxy Microsystems
Module Size:        8 GBytes
Memory Speed:        1801.8 MHz (DDR4-3603 / PC4-28800)
Module Temperature Sensor (TSOD):                                               Supported
Temperature Sensor Location:                                                    Front Side
Row: 2 - 8 GB PC4-28800 DDR4 SDRAM Galaxy Microsystems -------------------
[General Module Information]
Module Number: 2
Memory Type: DDR4 SDRAM
Module Type: Unbuffered DIMM (UDIMM)
Module Part Number:
Module Revision: 0.0
Module Serial Number: 0
Module Manufacturing Date: N/A
Module Manufacturing Location: 0
SDRAM Manufacturer: Samsung
DRAM Steppping: 0.0
Error Check/Correction: None
[Module Characteristics]
Row Address Bits: 16
Column Address Bits: 10
Module Density: 8192 Mb
Number Of Ranks: 1
Device Width: 8 bits
Bus Width: 64 bits
Die Count: 1
Module Nominal Voltage (VDD): 1.2 V
Minimum SDRAM Cycle Time (tCKAVGmin): 0.93800 ns
Maximum SDRAM Cycle Time (tCKAVGmax): 1.50000 ns
CAS# Latencies Supported: 14, 15, 16
Minimum CAS# Latency Time (tAAmin): 14.061 ns
Minimum RAS# to CAS# Delay (tRCDmin): 14.061 ns
Minimum Row Precharge Time (tRPmin): 14.061 ns
Minimum Active to Precharge Time (tRASmin): 33.000 ns
Supported Module Timing at 1066.1 MHz: 15-15-15-36
Supported Module Timing at 1000.0 MHz: 15-15-15-33
Supported Module Timing at 933.3 MHz: 14-14-14-31
Minimum Active to Active/Refresh Time (tRCmin): 47.125 ns
Minimum Refresh Recovery Time Delay (tRFC1min): 350.000 ns
Minimum Refresh Recovery Time Delay (tRFC2min): 260.000 ns
Minimum Refresh Recovery Time Delay (tRFC4min): 160.000 ns
Minimum Four Activate Window Delay Time (tFAWmin): 21.000 ns
Minimum Active to Active Delay Time - Different Bank Group (tRRD_Smin): 3.700 ns
Minimum Active to Active Delay Time - Same Bank Group (tRRD_Lmin): 5.300 ns
Minimum CAS to CAS Delay Time - Same Bank Group (tCCD_Lmin): 5.250 ns
[Features]
Module Nominal Height: 31 - 32 mm
Module Maximum Thickness (Front): 1 - 2 mm
Module Maximum Thickness (Back): 1 - 2 mm
Address Mapping from Edge Connector to DRAM: Standard
[Intel Extreme Memory Profile (XMP)]
XMP Revision: 2.0
[Certified Profile [Enabled]]
Module VDD Voltage Level: 1.35 V
Minimum SDRAM Cycle Time (tCKAVGmin): 0.555 ns
CAS# Latencies Supported: 17
Minimum CAS# Latency Time (tAAmin): 9.375 ns
Minimum RAS# to CAS# Delay (tRCDmin): 9.750 ns
Minimum Row Precharge Time (tRPmin): 9.750 ns
Minimum Active to Precharge Time (tRASmin): 21.000 ns
Supported Module Timing at 1800.0 MHz: 17-18-18-38
Supported Module Timing at 1733.1 MHz: 17-17-17-37
Minimum Active to Active/Refresh Time (tRCmin): 34.125 ns
Minimum Four Activate Window Delay Time (tFAWmin): 23.000 ns
Minimum Active to Active Delay Time - Different Bank Group (tRRD_Smin): 4.049 ns
Minimum Active to Active Delay Time - Same Bank Group (tRRD_Lmin): 8.150 ns
Row: 3 - 8 GB PC4-28800 DDR4 SDRAM Galaxy Microsystems -------------------
Module Number: 3
Module Part Number:
DRAM Steppping: 0.0
Number Of Ranks: 1
Bus Width: 64 bits
Die Count: 1
[Features]
XMP Revision: 2.0
Thanks. But that DBG file doesn't include sensor data, which I need. Please create a new one and make sure to also open the sensors window.
Thanks, but I cannot see any DIMM Thermal Sensor in that system. Are you sure your memory modules contain such? Is any program able to report per-DIMM temperatures?
Note that the "Module Temperature Sensor (TSOD): Supported" flag cannot be trusted because it might be set on modules, which in fact don't feature a thermal sensor.
[font=arial, sans-serif]I understand, maybe it does not have sensor as you indicate, anyway tayphoon burner indicates that yes:[/font]
Thermal Parameters
Module Thermal Sensor:
Incorporated
That's the same flag as HWiNFO is showing, but I really doubt there is one really present. Check your module's specifications if it supports TSE2002 (TSOD).
