External sensor/data
Bugs
Hello, my question is: Is anyhow possible to feed external data into HWiNFO? If yes, how can I do that and in which format?
I have my PC watercooled and I have temperature sensor directly in water. This sensor is connected to NodeMCU which calculates temperature from sensor and controlling PWM fans speed based on water temperature. My point is, I want to display this water temperature value in HWiNFO and display it by RivaTuner as OSD.
No, there's no such possibility. I'm not familiar with NodeMCU, is there some specification available for it?
I will consider adding support for a virtual sensor, which the user can use to submit data into HWiNFO via some interface (registry perhaps?).
