If I use a fan splitter cable for two similar fans connected to one motherboard fan header, would it be a problem for HWInfo? I mean, the fans will be running at the same speed (I guess?), but will HWInfo be confused which of the two fans it will get the fan RPM from? For example, one of the fans start to fail and runs at lower speed, from which fan will HWInfo take the speed from?
I'm starting a new build --- Maximus IX Code, i7 7700K, Cosmos II chassis.
I plan to do the following:
Case Fan 1 header - 1x 140mm - rear
Case Fan 2 header - 2x 120mm - side
Case Fan 3 header - 1x 200mm - front
