MikeWise1618
I am monitoring a machine remotely, and the new version is definitely better, but I do still have some oddities:
- The remote machine (UXIE) doesn't show up in the main HWiNFO window. Not sure it is supposed to, but it kind of looks like it should.
- When I add the remote machine, it comes in as two HostId instances, the first instance contains all but one of the sensors, the second instance just the Intel Core i7-4770T: DTS sensor values
- With the last version (6.08?) I could add the machine, and the monitoring worked - all the sensors coming in on the same Host ID, but it didn't register in the SharedMemory dropdown so I had to guess at the SensorInstanceID s which was quite a pain.
- The machine being monitored (UXIE) is a Windows 10 running the latest version
- The machine doing the monitoring is running Windows Server 2012 on a Intel NUC.
- While it works, I wouldn't mind getting rid of the dual HostID thing. Is this possible?
- The Enumeration option for remote monitoring works on one of the machines (UXIE), but not the other (the Server 2012) machine.
- The Enumeration option doesn't pick up the "correct" IPs, it pickes up 10 values that might have to do with a VPN I am occastionally logged into.
- Also I was wondering about the Rainmeter plugin HWiNFO.dll. When there is a new version, do we need a new version of that too?
Great product by the way. Suggest you ought to have a paid version with logging - would be worth it.
Thanks in advance,
Mike
Thanks in advance,
Mike
