GPU RPM stuck at some value when MSI After Burner launched before or after HWINFO
wawans1975
i just noticed one sensor for RPM stuck at 734 (may be some other sensors stuck too?) and as i exit msi ab, the rpm back to 0 rpm, same as msi ab reported.
Debug file, log file and screenshot attached.
  • HWiNFO64.zip
Try to disable monitoring of the entire GPU sensor and then try MSI AB if it happens too.
monitoring disabled for entire GPU sensor and then load/unload MSI AB several times, GPU RPM didnt stuck at MSI AB, still at 0 RPM when GPU idle, also RGB Fan Stop is On all time.
I am noticing other sensor, fan speed at MSI AB stuck at around 11%, but RPM at 0%.
As for now i have close HWinfo , and at MSI AB fan speed still at 11% , GPU FAN RPM at 0, RGB fan stop is ON.
Now I open MSI AB with HWINFO still open, the result is at HWINFO: GPU FAN RPM at 734, GPU Fan Speed at 11%,
at MSI AB: GPU FAN RPM at 0, GPU Fan Speed at 11%
and RGB FAN STOP is ON.
Now i close MSI AB with HWINFO still open, the result is at HWINFO: GPU FAN RPM at 0, GPU Fan Speed at 0% and RGB FAN STOP is ON.
lol, i forgot to mention that i use custom fans speed at MSI AB, seems the problem come from there. As i turn it off, HWinfo sensor for RPM and fan speed are back to normal..
Sorry for this.
