Help with Fan Conrol configuration!
IntSed
Hello!
Can Somebody help with Fan Control configuration?
I have Dell G5 15 5587. (there is pc specification)
I start use SpeedFan (have simple cofiguration) but configuration skipped almost every time i restart PC.
Image below presents lot of Thermal Throttling with very passive Fan operation and high PC temperature.
Please any suggestions to HWiNFO Fan configuration!
Thanks!
Bekarfel
Hello!
Thanks!
Hello!
Is the fan running at any time when your notebook is on? If they do spin, then look in your BIOS for fan control settings, or contact Dell for support with this issue.
If they never spin up you may consider disassembling your laptop and cleaning out the radiator grille and fan shrouds, and verifying working operation of the fans. If they don't spin when you turn the computer on then they are faulty and need to be replaced. Dell has released a service manual for disassembling and reassembling this laptop model on their website.
