Hwi64 showing CCD1 temp 145c on r5 3600x
passed 8 hr realbench stress test no hwi64 issue shown.
it very well could be from Occt giving the false readings.
I see, thanks for the extensive tests and reports! I will check this with the author of OCCT.
Hi Martin
Here is aida64 extreme running cpu-cache and mem test for 14 hrs. no issuse.
So it seems to only be Occt shows false values for some reason.
And I will take it that My Oc and tightened and Oc'd ram is stable with all the testing and No failures other then Occt showing negitive results but no failure there either.
Thanks for Your Help and Support
if I can will help more if you need more results.
