HWInfo and RTSS - OSD Toggle
Mforeman81
Good evening all,
I recently swapped motherboards (long story) and have seemed to have lost the ability to toggle the OSD on or off. I am using 6.42 HWInfo and 7.3.10 RTSS. I did a compete team-install of both. Iirc, I had setup the OSD toggle in HWInfo as Ctrl+Shift+X. I’ve tried changing the keys but it just won’t switch off!
same issue in all games. Any ideas?
Maybe that combination is already used by something else? Try a different one.
Mforeman81
Thanks for the quick reply, Martin.
Do you have any suggestions for key combinations that seem to work and don't conflict with standard applications? I just tried a few, no progress.
