HWInfo error
FreddyPL
There is an error while detecting ATA/SATA drive with AsMedia ASM1061 SATA III controller.
A running program freezes the computer and only helps the reset
FreddyPL
Yes, I try with factory driver, and now I have standard driver - always freeze
Now I try use driver proposed by SDI (Snappy Driver Installer and all is OK)
FreddyPL
you're welcome, thanks for help, and regards
BTW, Why You don't support AS106x series controller?
