Hi, I've been running into issues where the hwinfo64 program would freeze and crash on "Detecting CPU #11" when I attempt to run "Sensors-only". Any attempt to run it again after the error occurs would result in the same error. The only "work-around" I've found is to force-reboot the computer and start the program then (see below for why it must be a force reboot). I've only used hwinfo64 for a few days, and this had already occurred multiple times. Any help/advice would be appreciated.
CPU: Ryzen 5 3600X
Motherboard: Asus Prime X470-Pro (BIOS Version: 5204)
OS: Windows 10 Pro
Some observations:
- Most of the time, this error occurs after I have ran the program beforehand (e.g., I boot the computer, start hwinfo64 successfully, close it, and then when I try to start it again, it runs into this error).
- Sometimes, all the stats on the sensors page would freeze (even though polling is set to 2 sec), and after I close hwinfo64 and run sensors again, I get this error.
- After this error occurs, I am unable to shut down or restart my computer. I can click the "Restart" button and Windows would exit as expected (it would close ongoing tasks; no more signal would be sent to my monitor), but my computer would still be clearly running (fans on, lights on), and would not reboot at all. I would have to force shut-down the computer and reboot then. In contrast, when this error has not yet occurred, I am able to shut down or restart my computer. This seems to suggest that when this error occurs, hwinfo64 has sent some command that hangs and keeps the computer awake somehow.
Edit: added some clarifying details
CPU: Ryzen 5 3600X
OS: Windows 10 Pro
Some observations:
