Is my CPU okay?
aspergers0
I'm running on a laptop ASUS TUF FX505DT. CPU: Ryzen 7 3750H, GPU: GTX 1650 4gb gddr5, 16gb ram, external display(monitor) connected to the GPU.
When I'm gaming I have no issues. I don't have drops in performance or anything really but I notice my CPU reaches max temps around 100 degrees celsius(While under load it's basically around 80-85 but there are spikes, this is to be expected). On the offial AMD website it states that the max temp of this processor is 105, but I'm wondering if these readings on HWInfo are correct. It says it's not throttling but I'm suspicious about the temps, is this normal? Any answer is appreciated!
I believe those values are correct, but most likely some short spikes. High temperatures on notebooks are quite common as thin designs are not capable of dissipating enough heat and even thermal throttling is common there (expected by design).
