RE: Lost CPU Fan Spped Sensor Reading
Your right - I never looked there. On 4.20 it is at the end of the list (I have not checked the other versions - I am just running 4.20 at the moment).
OK - 4.24 works the same as 4.20
Evidently I have a "funny" board that does not report correct sensor values until I "poke" it (i. e. get it to run at a higher multiplier than 5X). After that it seems to do OK (in that I can see speed fan and HWINFO both winding down after stopping prime95 - HWINFO still hangs after a bit though).
Thanks - I think I can live with the fan speeds being reported as they are. I just have to remember to "poke" the CPU first (hmm - I will have to see if my underclock at 5X is actually working as well as I expected).
Good show - thanks for your help.
