Memory Integrity/Microsoft Vulnerable Driver Blocklist disables fan readings
SpoDenBeef
I recently updated to Windows 11, and it was running fine for the first couple of days. Then, an error popped up saying that SSGDIO64.sys had been blocked. The fan readings showed up as red circles with X's and wouldn't display properly. I turned off Memory Integrity and the Microsoft Vulnerable Driver Blocklist and restarted my PC. Only then did HWiNFO start reading my fan speeds.
Is this a Microsoft problem, or is it the app's problem? Since it's a .sys file, would it be fine to assume it's the former?
SSGDIO64.sys is not our driver.
Fans shown with a red X mean the reading is disabled by user.
I didn't disable it, so it might just be Windows breaking itself, I guess. I thought it was the app's driver, since it suddenly worked when I turned off Memory Integrity. Thanks, I suppose.
Just hit the Ins key over items with red X to enable them. The problem with SSGDIO64.sys is something else, probably Windows blocks the driver because it's vulnerable.
