Minimal resource consumption : I only need to use 6 sensor....
MKANET
I currently only need 6 sensor info to be available via the RESTful Web Server addon to be used by Home Assistant.
QUESTION: If I disable monitoring for all sensors except for CPU temperatures and core clock speeds (no network or disk info, would that significantly reduce CPU consumption? Or, does it not make a significant difference?
If anyone has some.tips to reduce HWINFO's resource consumption as minimal as possible, please let me know which settings to focus on.
Yes, that should reduce the usage. Make sure to also disable the sensor headings.
@Martin when you say disable "sensor headings", do you mean CPU [#0]: Intel Core i7-4790k in the screenshot below?
I also disabled logging for all sensors. However, I'm not sure if that is a bad idea. Everything still seems to work good.
