Missing some SYS_FAN_PUMP Sensors
ravenium
I've loved just about everything about this app, except one thing - I'm missing a couple sensors (SYS_FAN8_PUMP being the most noticeable since it's connected to my pump (cable length and all). I can see FAN5 and FAN6 pump sensors, but for the life of me I don't see 7 or 8 (they show up in the BIOS).
It's a Gigabyte Aorus Master X570S if that helps. Thanks!
Those should be reported under a dedicated sensor called GIGABYTE EC. If you don't see this and have this sensor monitoring enabled and EC Support enabled as well, please attach the HWiNFO Debug FIle and I will check in detail why it's not showing up.
ravenium
It's definitely picking up the other sensors (rad fans on CPU with correct RPM, a couple of EC_TEMP_1/2 sensors that I have attached to the coolant, etc). I looked and tried with both enabled and disabled a couple times just to be sure :)
Thanks for the assist!
  • HWiNFO64.zip
ravenium
@Martin Apologies for the wait - I completely missed the forum notification. In any event I updated HWiNFO today and can verify it is now reporting FAN7_PUMP and FAN8_PUMP. Thanks again for running this down!
I do notice that the reported RPM hasn't changed in an hour of uptime - that could be true, but it seems a bit odd. Should I add another debug file?
That seems like some issue, does the initial RPM shown match the expected speed? Please attach the HWiNFO Debug File, I need to check the details.
ravenium
I checked in the BIOS and it was doing the same thing - maybe a bad connection or pinout. I swapped to FAN6 and it works just fine. Darn Gigabyte :) All is well now, thanks again!
Amasov
Happy New Year :)
thinking, that the same issue is on Gigabyte Aorus Master X670E. SYS_FAN7_PUMP and SYS_FAN8_PUMP are not showing up. Since I configure my Fans in BIOS, all fine there. The nearby CPU_FAN (to 8) and SYS_FAN6_PUMP (to 7) are shown correctly in HWINFO.
I appreciate it if you may take a look.
Thanks,
Chris
  • HWiNFO64.7z
HWiNFO has support for those fans via a special dedicated sensor but it looks like something in the system blocks access to this device.
Try to enable the "Low-level PCI Access" option in HWiNFO if that will maybe help.
Amasov
Thanks Martin.
I'm sorry, unfortunately nothing changed so far. I searched the hidden values as well - didn't find the lost sensors. I also unchecked the 0x0 to 0xF SMBus Device Exclusions and reset whole Program. After that, I took the the Beta (v7.35 - 4950), but still no change - Everytime in mind to check Low-Level-PCI Access. Still as before.
//edit
Tested with 32-Bit (Beta) - no change.
//edit2:
Just want to prove that a Fan is installed ...
I'm wondering whether Virtualization / HVCI (Core isolation) or Secure Boot might be the reason for blocking access to this device.
You might try to disable all those features to see if that will help.
Amasov
I appreciate your efforts. Thank you!
Both turned off stepwise and still no effect. :(
Maybe its related or not: After a while HWINFO is running, the Chipset (xHCI) Temperature is showing up. Sometimes already at Start, sometimes about an hour later. Just now its not showing, I will make a screenshot, when its back.
Please attach a new Debug File with all those features disabled and"Low-level PCI Access".
Amasov
Attached.
//Edit
And here the mentioned Sensor, which is showing up sometimes:
  • HWiNFO64.7z
Thanks. There's an alternate method how to access the device responsible for the remaining fans, but it's a bit complicated to implement this and will require some effort.
Please run this build: www.hwinfo.com/beta/hwi64_735_4952.zip
and create a new Debug File using it. This build is just to give me more information how to implement support, so it won't work yet.
Amasov
attached the corresponding 4952-Debug File. Thank you.
  • HWiNFO64-4952.7z
Thank you, I'm working on this but it's a more complex task...
BTW, have you maybe ever used the RW-Everything tool? It might be helpful if you could create some memory dumps using it from the FF010000 and FC010000 regions.
Amasov
I haven't, but I downloaded it. Something to take care of ?
Assuming you would like to have this (as a binary?) - what length you're preferring from both of the adress regions?
