U sure? Z-cpu show the same thingMost likely due to:
IMPORTANT - Core frequency reading in Windows 11
I'm getting some odd looking core frequency readings with the current HWiNFO in Win 11. Is Win 11 supported yet? Screenshot attached.www.hwinfo.com
haha yes, but somthing is wrong? it was like that from acerWell, the Bus Clock is above 100 MHz, and 41 * 128.17 MHz is about 5254 MHz.
Regards
Dalai
Here u goDo you maybe have Hyper-V enabled?
Please attach the HWiNFO Debug File so I can analyze more details.
MB, think it's right nowI'm sorry but that file was overwritten. You should not start HWiNFO again after you created the dump as that will overwrite it. So run full in Debug Mode, close it and post the file again.
idk, if it's important, but my ACPI and RTC timers is not synchronized.View attachment 8736
Ty! yes it's normal nowYes, problem is the BCLK which can't be determined reliably here (as no reliable method works here), so the value estimated fluctuates a lot.
I have implemented a workaround for this case, but not sure if that will work.
Please try this build and let me know the results: www.hwinfo.com/beta/hwi64_737_4981.zip
If any issue, a new Debug File will be needed.
