pressing enter with mouse on top of hwinfo window will minimize it
skyisthelimit
I do not know if this is by design or is there a way to fix it. I have hwinfo open up at another monitor and while gaming, some time my mouse accidentally hover toward that monitor. when i press "enter" as an action in that game, the hwinfo window will minimize by itself. and i have to reopen it again. it is very annoying that why pressing enter minimize the window? and there is no way to disable that?
This is a common user-interface feature. The default button is the Close button that does minimize the window or close the application depending on how it's configured. You can switch to a different default button by pressing the Tab key.
I assume you have the sensors window open. Pressing the Tab key there will change the default button.
still nothing. I tried pressing tab on all the window. still nothing popup. Basically my monitoring display look like the screen shot in attached.
Noting will popup, but pressing the Tab key changes the default button to a different one, so when you accidentally hit Enter while HWiNFO window is active, it won't close it.
