Martin said:You can't directly compare temperatures in BIOS with those in Windows, because the conditions are very different.
Also, I need to rely on manufacturer's information and their tools, since only they know the exact sensor mapping on a particular mainboard.
Anyway, HWiNFO shows you also the other temperatures and if you believe a different one is the correct value, then just rely on it![]()
Martin said:Is the "CPU (PECI Calibration)" similar to CPU Core or Package temperatures ?
Martin said:I will rename this in the next build.
I wish mainboard manufacturers would care more about reporting correct temperatures and differentiate between internal and socket values.
