Remmaing life not display correctly in sensor data for Samsung 840 Pro SSDs
In comparing the s.m.a.r.t, values (sensor panel) for SSD devices against another reporting application (SIV64X), there seems to be an incorrect value for remaining life stated in this application for Samsung 840 Pro Series SSDs.  For example, SIV64X is reporting 12 bad blocks/86% remaining life, HWinfo (5.20-2800) (64-bit) does not report bad blocks and the remaining life is at 99% in the s.m.a.r.t. section.  Would like to see bad block and the correct correlated remaining life in the s.m.a.r.t. area of the sensor display.  Would also like to see the device serial number displayed in the drive section to be able to correlate it to the same drive displayed in the s.m.a.r.t. section.
Please post a screenshot of the respective HWiNFO section including complete SMART information, so I can see all the details.
Also, are you sure that SIV is showing the correct information? How about comparing with some other tool, i.e. CrystalDiskInfo ?
