DoneMartin said:Please attach the HWiNFO Debug File of situation with RPM=0 and I will check that.
Martin said:I see, thanks.
Please try this build and let me know the result: www.hwinfo.com/beta/hwi64_583_3413.zip
Please also attach a new Debug File made using this build.
Martin said:Sorry, I forgot to tell you that after enabling the "GPU I2C Support Force" option, you will need to press the "Reset GPU I2C Cache" button and then start HWiNFO.
Can you please repeat the test run?
Martin said:Another theory might be that for these cards a fan speed of ~1330-1370 RPM (~40-41%) means off.
What if I would implement such filtering ?
