Show OSD Graph without current value? Display stat name on top of graph?
Is it possible to display OSD graph and only the graph, no value of stat displayed (its showing on right side of the graph)?
Asking for this because i would like to form a grid of graphs and cant do that when values are in the way. Also, is it possible to display stat name on top of graph (within its square) instead of next to it (from same reasons as above).
If you're missing some RTSS OSD features in HWiNFO you might try the other way - MSI Afterburner with the HWiNFO plugin can pull all data from HWiNFO and display them in OSD.
Showing graphs is RTSS feature?
Or its HWinfo that creates graphdata and just sends it to RTSS for display?
HWiNFO just puts instructions to create the graph, which is then rendered by RTSS.
So similarly to how HWiNFO instructs RTSS to display statistic for example without unit, with changed unit or with changed name
would it be possible for HWiNFO to instruct RTSS to render only and only the graph without the current graph value?
