[SOLVED] iCUE has stopped receiving data from DRAM while working with HWiNFO64 (Sensors-only)
Drakomord
Greetings,
I'm having an issue with my Vengeance DDR5 DRAM in iCUE when HWiNFO64 (8.0.0-5400) is running at the same time.
Lights are struggling/blinking until iCUE lose total control and stop receiving data from DRAM.
First I thought it was my modules so Corsair replaced them but after installing the new modules, the issue was still there. Then I looked deeper and find out that there was an uncompatibility between Corsair iCUE and HWiNFO64.
I've read that by unchecking "CorsairLink and Asetek Support" it could resolve the issues with iCUE but unfortunatly it doesn't work for me.. iCUE is still struggling with DRAM while HWiNFO is running.
For the record, I'm using HWiNFO64 to monitor CPU/GPU temps and load on my StreamDeck with this followed awesome plugin : https://github.com/shayne/hwinfo-streamdeck
I've set up HWiNFO64 as specified in the main plugin page. Here's my actual configuration (screenshot below).
Thanks in advance for your help! (and sorry if my english isn't perfect)
iCUE doesn't work well with any other monitoring software and Corsair is not interested in fixing this and cooperating with others.
There are dozens of similar threads here.
Thanks for the quick answer and you're right it's actually what I've already read in other threads but I had hope that you or someone else had a trick to disable the part who's conflicting with iCUE and causing the issue. Like disabling DRAM monitoring (I don't need it) or anything else in HWiNFO to leave iCUE free to manage it without conflicts? If possible I would like to know how to do it please.
Also, I still have my ticket open with Corsair and I didn't say that I have figured out the cause to let them work on it because they should fix it or at least cooperate with devs like you. We'll see..
I don't think there's some trick. Problem is that iCUE sends RGB commands to DIMMs and HWiNFO accesses them for monitoring. Perhaps disabling monitoring of DIMM sensors in HWiNFO can help but there's no guarantee.
Alright then, I disabled monitoring on the both DIMM controllers from there (see above). Now, I leave it like that and we'll see.
I'll post an update if it helps, for people in the same case as me.
Thanks again for your help and your work on this software.
Hey, I'm back with some (good) news!
I finally got it to work, what I've done in my precedent answer wasn't the solution but after multiple tries by disabling and enabling the monitoring of few sensors by group I found out the culprit sensors.
By disabling monitoring of whatever mentions the "Renesas RAA229131" PWM controller, iCUE seems free of any conflicts about the DRAM. Even with everything else enabled.
I don't know if it helps but at least if someone else is having the same trouble, here's the solution.
I mark the topic as "SOLVED" and leave it there. And once again, thanks for helping me to find this out!
Cheers!
Cheers!
I came here with the same issue as you had, the ICUE DRAM warning was appearing all the time while using HWINFO, and your solution also works for me. I also have the MSI MPG Z790 carbon, so probably no surprise there! Thank you so much, really appreciate it.
Cheers!
This got me in the right direction. I'm using an ASRock X870e Taichi lite. I disabled the Renesas monitoring but that didn't work. I noted a little bit below there is the Corsair Commander CORE as well. Disabling monitoring for the Corsair Commander CORE did the trick for me =). On my previous motherboard there was no need for this but it was a less fancy mobo so idk. Cheers!
Edit: Disabled the Corsair and Asetek support option which completely gets rid of Corsair Commander Core monitoring. Additionally disabled Renesas RAA229131 as mentioned by Drakomord and that seems to completely do the trick. The enabled Corsair and Asetek support option makes it seem like it needs to be enabled for iCue (at least, it did for me) but iCue only seems to conflict with it. I'm guessing it's for Corsais/Asetek hardware without the use of iCue. Anyhow, works fine again!
Cheers!
hi, i just wanted to ask if im experincing the exact same issue as i got this notification when starting hwinfo, wanted to know is this is the same thing you got too since my ram is displaying the same symptoms you described while i have hwinfo running in the background. and if we've got the same issue, how did you figure out it was the "Renesas RAA229131" thing?
this i what my hwinfo page of sensors looks like is there anything on there that indicates i should disable it like you did? how do i know which ones are causing the issues?
nevermind ignore me im incredibly stupid, i see now down the list of sensors there is a rensas one...
