Yes, there's no reason why it should not be compatible.
If there are any issues, just report them and I'll look into that, so wondering what weird things have you experienced.
As I have mentioned, and the first time I have installed, everything was fine. Later I have turned off hyperthreading, as my particular application does not benefit anything from it, and thats were the things got tricky. I configure HWInfo usually to start at the system start, minimized on the tray, showing the CPU Package temperature, memory usage, CPU utilization and GPU temperature. In this system I have to CPUs, one have disappeared. However, if I start the program with the main window, and from that start the sensors, everything is ok.
The other thing is, that sometimes some under the Nuvoton NCT7904D not existing fans show up, like Fan 11, altough the system has eight headers, and report crazy rpms, like 46000rpm. The system voltages are reported at the same space, and it was also strange that a few times at the +12V much bigger values (like 27) were reported and the same happend once for the CPU VCore, which for this board is the VCCin, I gues, as there in spite of the normal 1.8V once ~4V was reported.
A bit scarry for me, as the PC is used remotely, so I can't smell, if the reason is a faulty VRM or just missreading.
Otherwise it is a really great program, I'm using it on different computers, and it is working perfectly on the others.
