Taskbar System Tray Icon Duplicated
rhrhd
I just realized that HWinfo64 creates so many toggle, on Windows 11 Pro 22621.1848 settings\personalization\task bar\other system tray icons (for more information pleas see attached image)
Because of that, I'm scared to update HWinfo64. because everytime I updated it (uninstall and install the new one), it creates new toggle on settings.
How to clear it?
There must be some icon configured for appearance in the tray/notification area. Check the "In Tray" column if you see some active.
You might also try to completely "Reset Preferences" in HWiNFO to get rid of all such icons.
