Tray icon color change, when temperature has increased a threshold level
Hi, Martin
Hwinfo is the best monitoring tool in the whole internet, just amazing no more.!
Maybe there is an option, but i cannot find in the software menus, is there a way of changeable tray icon, when temperature has increased a specific level
E.g. when cpu temp exceeds 70, it becomes red, below it yellow, and green.
If not, could you add an option for the next releases .
thx, and keep up the good work.
Thank you :)
Yes, there is such an option. First you need to specify an Alert with your threshold and then enable the "Depends on alert threshold" option for the tray icon.
