Two Vcore Sensor Readings
IamRaeff
Hello Everyone,
Just a quick question on sensor status readings. I noticed on the Mobo section, that there are two Vcore sensor readings. It is listed as:
Motherboard Temp
CPU Temp
Auxiliary Temp
AUXTIN2 Temp
AUXTIN3 Temp
CPU (PECI) Temp
Vcore
+5V
AVCC
3VCC
+12V
PCH +1.0V
3VSB
VTT
Vcore
VCCIO
DRAM AB
DRAM CD
VCCSA
Chassis 3
CPU1
CPU Optional
CHassis 1
Chassis 2
I know what the sensors are, but I want to know why there are two of them.
Very Respectfully,
IamRaeff
IamRaeff
I should also note that I am using version 5.88-3510, and that the program is running on a separate machine with no internet access at the moment, otherwise, I would have posted a screenshot with it. I can get one with a flash drive if need be. I figured the question could be answered without it, however.
