cryptocharlie
Hi HWiNFO64 has always been reporting correct GPU Hot Spot Temperature until I upgraded to 7.22.
My GPU is 3090, I can tell its correct Hot Spot Temperature for almost a year now, since I started ETH mining with the GPU when the PC is not being used. The sensor is a key indicator, which normally reads between 104 to 110, and 108 is a sweet spot. If it's above 110, it means the GPU is heat throttled, which is not ideal, and 110 is the maximum reading, in which case I need to cool down the environment of my PC by adding fans to blow out heat from around the PC.
But since upgraded to 7.22, it shows only 64 degree, this is not right, this is GPU core temperature not the hot spot one. Another app iCUE (Corsair dashboard) still shows the correct GPU hot spot temperature:
Please verify the bug. Thanks!
