Hi, don't want to hi-jack this thread, but it seemed the best place to post.
I'm wondering if the 18c PCH offset was removed for the Z77X-D3H and perhaps should only have been for the Z77X-UP5? (I believe Stasio replaced his D3H with a UP5 partway through the thread?)
I have the Z77X-D3H with the latest official F9 BIOS, and I'm getting inconsistent readings for PCH temp between 4.00-1680 and 4.01-1695, and checking ET6 (and in the BIOS itself) makes me think 4.00-1680 is the one giving the correct reading.
HWINFO screenshot
I have 2 instances of HWINFO open, on the left is 32bit 4.00-1680 and on the right is 64bit 4.01-1695. (But both the 32bit and 64bit versions give the same result, this was just so that I can have the 2 versions open simultaneously.)
I've checked in the BIOS itself and the higher PCH value is reported there as well - screenshot below.
BIOS screenshot
Debug files as well in case they help.
Please let me know what you think, and if there's anything else I can do. Thanks.
