Martin said:I think that happens because the GPU is disabled by NVIDIA Optimus (not used). I'll try to fix the crashing.
Martin said:I see, it seems my assumption was wrong. I'm checking it right now... Does it crash for you too sometimes as zach9054 ?
When it says the value is disabled, are you able to choose a Temperature 1 source from the drop-down list ?
zach9054 said:Martin said:I see, it seems my assumption was wrong. I'm checking it right now... Does it crash for you too sometimes as zach9054 ?
Not if i pick gpu. When compal is enabled, it always says cpu under and shows the fan. sometimes gpu shows up too. Biatche's picture doesn't have gpu showing up in sensors.
Biatche, if you're reading this, try opening up your nvidia GeForce expirence program and then exiting out. See if the brings gpu up in sensors like in my pic. If not restart Hwinfo
biatche said:Pity I don't have GeForce experience installed. I never install it.
biatche said:"Technologically" speaking, how would you make this work correctly around 'Optimus' problem?
