Disconnect in displayed GPU info
ritjesman
running v7.26-4800 (I had updated to your latest & greatest but found the orangish text color on the entry screen sys summary difficult to read so reverted to earlier version with black text)
new hardware i9 14900K with onboard graphics and an Nvidia RTX 4060. both are shown on the main screen/window and the 4060 on the sensors window (as expected) but its the Intel video adapter that's displayed on the entry sys summary window.
Is there any way to change that?
Thanx.
Not sure what exactly do you mean without seeing a screenshot but if you have a GIGABYTE board then it's most likely the AORUS theme used by HWiNFO. This can easily be disabled in main settings.
ok - thanx for quick response.
but main question was why 4060 not is showing on entry summary page HOWEVER just saw the GPU 1/GPU 2 dropdown so sorry to have bothered you ..
