I guess you are tried to do this in hardware, programming the fan controller directly? A fast solution is to read CPU temp, and have the fan setting (fan slider in fan control) adjust automatically in HWiFO software ( I would keep HWiNFO minimized, or you can make it a separate utility maybe) . Can you implement that feature please?Martin said:I was trying to implement this option in the past, however the problem is that the representation of temerature in the fan tables is not in Celsius and I don't know how to convert/interpret that value.
ooooooo said:I guess you are tried to do this in hardware, programming the fan controller directly? A fast solution is to read CPU temp, and have the fan setting (fan slider in fan control) adjust automatically in HWiFO software ( I would keep HWiNFO minimized, or you can make it a separate utility maybe) . Can you implement that feature please?Martin said:I was trying to implement this option in the past, however the problem is that the representation of temerature in the fan tables is not in Celsius and I don't know how to convert/interpret that value.
Yes, you are right.Martin said:since software can freeze or crash
Can you post those values, so I or someone else can maybe help convert?Martin said:representation of temerature in the fan tables is not in Celsius and I don't know how to convert/interpret that value.
ooooooo said:Non-persistent changes are even better. If anything goes wrong people can just restart.
The changes would have to be user configurable. Otherwise, I don't see how it would work on different systems. For example, on my system lowest RPM value is 3000 and highest is 7000. So any fixed value like "Change 2. to 2700RPM and 3.&4. to 3500RPM" would not be useful in my situation.
ooooooo said:Quick question, is it possible to make settings permanent?
ooooooo said:I meant make the LUT changes permanent, even after restart. I didn't know the BIOS reconfigured the LUT on each restart. Any way to lock LUT?
