ok! Updated to latest, 4.36Martin said:Please use the latest HWiNFO version and post here the HWiNFO Debug File with sensor data for analysis.
OpenFanCtrlMin=1
I've used this option to start HWiNFO, is there a option to force fan..?. HWiNFO starts but FAN not. In fact, OpenFanCtrlMin=1, was disabled because HWiNFO freezed on autostart with debug enabled.Martin said:If you want to automatically start fan control in HWiNFO, add the following line at the end of HWiNFO64.INI file:
OpenFanCtrlMin=1
This might be used together with other autostart options in HWiNFO to achieve automatic start with fan control in minimized mode![]()
Unfortunately does not start... it only starts when AC power is on... Is there a way (gadget, HWiNFO64.ini...) to call/enable FAN? (like click in icon, manual mode and adjust speed)Martin said:Fan should automatically start with that option. You don't need to use Debug Mode in normal runs, only if you want to send me the DBG file.
Precisely... OpenFanCtrlMin option is enabled, fan only runs if I manually open the Fan Control.Martin said:So when running on battery, the fan does start only if you manually open the Fan Control and doesn't when you have that OpenFanCtrlMin option enabled?
