Global polling rate + debug mode = settings GUI drawing problems.
Timur Born
Ahoi.
Thanks for the latest version (6.40). Small issue: when poll rate is under 200 ms and Debug mode is enabled then HWinfo struggles to draw its own GUI in the settings window. When I switch tabs it only managed to draw a single line and leaves the rest of the window blank.
Regards!
Thanks for the feedback regarding this change. I did quite significant changes to polling in the last version.
Debug Mode was not meant to be used in normal environment, so I don't consider this as a serious issue in case such a low polling rate is used. Try to disable the "Debug Write Direct" option, that should improve the performance in Debug Mode.
Timur Born
And thanks for this change indeed, it is well appreciated! :)
You are correct, disabling Write Direct solves this little problem and it is not significant. Just reporting FYI.
