Hi Folks,
This is my very first post on this forum, so - hello everyone!
Having just installed HWiNFO32 on one of my PCs, I am impressed by this software. However, it is incorrectly reporting the CPU temperature. It has correctly identified an ASUS ASB100 sensor but I presume that's on the motherboard. It has also correctly identified the CPU as a rather aged Intel Pentium 4-1800. The CPU temperature reported by HWiNFO32 is 32.0 degrees C in each of the three columns (current, min and max). The actual temperature indicated by other software running on this PC is 48/49 degrees C. Interestingly, under the Enhanced Features section for the CPU, it states:
Thermal Monitor 1 Supported, Disabled
Thermal Monitor 2 Not Supported
I suspect this information is key to the problem I'm seeing but I don't know how to enable the Thermal Monitor 1 on this CPU. Also, does that mean that this CPU has been running since day 1 (many years ago) without internal thermal protection? Why would it be disabled?
Would anyone care to point me in the right direction?
Thanks in advance.
JPC
Thanks in advance.
JPC
