realkencab
BEFORE YOU CONTINUE: This is not for "dumb hubs/controllers" that are just essentially multi-port splitters that typically read the RPM off of the first fan only.
I've been trying to find a comprehensive list of fan hubs/controllers that have individual RPM readout that is supported by HWiNFO. These hubs/controllers are usually connected via USB, meaning protocols aren't the same, so I understand why not everything is supported. So far, these are what I have been able to find using the forum's search function, and also by checking the version history. It's a pretty difficult task since searching for keywords that are 3 characters or shorter will return zero results, so I can't search for "fan" and "hub". I've mostly found this by searching for the brand and models of hubs that I know exist:
Legend:
Untested/Can't find info:
Brand | Model | Compatibility | Details | Source | Product Link |
Aquacomputer | Aquaero | Supported | 4-channel controller | Verion History (as of v4.48) | Link |
Aquacomputer | Octo | Supported | 8-channel hub | Verion History (as of v6.22) | Link |
Aquacomputer | Quadro | Supported | 4-channel hub | Verion History (as of v5.92) | Link |
Aquacomputer | PowerAdjust | Supported | Single channel controller (3-pin) | Verion History (as of v4.50) | Link |
Corsair | iCUE Commander Pro | Supported (YMMV) | 6-channel hub "Corsair Link Commander Pro" is listed as supported on HWiNFO v5.54. I'm assuming that the iCUE version is just the same. | Verion History (as of v5.54) | Model: CL-9011110-WW |
Corsasir | iCUE Commander Core XT | Supported (YMMV) | 6-channel hub | Verion History (as of v7.42) | Model: CL-9011112-WW |
Corsair | Commander Core | Supported (YMMV) | 6-channel hub Included in all Corsair Elite Capellix Coolers | Verion History (as of v7.42) | Model: CW-8960071 |
NZXT | Control Hub for Case Fans and RGB Lighting V2 (Shows as Smart Device 2 in NZXT CAM) | Not Supported | 3-channel hub Included in the NZXT H510 family of cases | Link | Model: AS-SDV02-A1 (cannot purchase individually, no product page) |
Legend:
- NZXT RGB & Fan Controller (AC-CRFR0-B1)
- Lian Li UNI HUB L-Connect3 Controller (12SL-CONT3) - fan controller that comes with Lian Li UNIFAN SL/AL fans
- Razer PWM PC Fan Controller (Link)
