MSI X99 GAMING PRO CARBONE ring/sa voltages
zelante
Can I ask for add some enhanced monitoring in future version hwinfo64 for MSI X99 GAMING PRO CARBONE (NUVOTON NCT6792D+) ?
Want to see cpu system agent voltage in it. If it possible what information i should post here?
wbr. Oleksandr.
RE: MSI X99 GAMING PRO CARBONE
Is the System Agent voltage reported by the MSI Command Center or BIOS as a monitored value (not a setting) ?
If yes, then a screenshot side-by-side with HWiNFO sensors would be helpful.
And the Debug File as @desgen already mentioned (thanks).
zelante
Thank you guys, for so quick response!
Here is some screenshots and dump file
[attachment=2557]
  • hw001.zip
Thanks for the data.
I have to admit, that I don't know where to read the CPU SA and Ring voltages.
I will check this with MSI, it might take a few days until I get a response.
zelante
Thanks!
Just find that HWMonitor is showing many voltages but without "normal" labels (show like VIN1, VIN2 ...)
[attachment=2558]
OK, I think I found them :) Will be fixed in the next build ;)
This issue should be fixed in the new v5.61-3297 Beta.
zelante
Confirm! Great work! Thank you!  :D
[attachment=2565]
RE: [solved] MSI X99 GAMING PRO CARBONE ring/sa voltages
Thanks for the feedback :)
