givemebreak
I'am using Asus Maximus Z790 Hero, 13900KS CPU, Corsair HX1000i(2023) PSU and Lexar LD5U16G72C34LA 2x16GB memory with XMP enabled at 7000MT/s.
Sometimes SPD info(on screenshot) disappearing from HWInfo and other programs.
It happens after playing Red Dead Redemption 2 for a long time (about 1,5h).
It also happened right after booting (the computer was previously unused for many hours).
When the problem occurs HWInfo program turns on longer than normal. Mainly during memory configuration analysis. It uses 100% of one CPU core while loading.
In this state, after restarting the computer, memory training will start, which will end with q-code 55(memory not installed).
However, if instead of rebooting I turn off the computer and cut off the power, it will turn on normally again.
Surprisingly, immediately after this problem occurs, I can run Karhu Ramtest or TestMem5 and they do not show errors.
In addition, when testing in Karhu Ramtest, sometimes SPD Hub Temperature grays out and does not update, but after a few seconds it comes back on.
I also own another set of RAM - G.Skill F5-6000J3040G32G 2x32GB 6000MT/s. With them, something similar was happening except that the SPD information disappeared only for one DIMM.
I have attached the log files from HWInfo.
What's going on? Is it the motherboard that is defective? Please help.
