Z77X-D3H/Z77X-UP5
RE: Z77X-D3H
Hi stasio,
I have rewritten the PMBus VR support and need to test it. Could you please run a test with this Beta:
www.hwinfo.com/beta/hw64_394_1576.zip
and attach a new Report File, or a screenshot of the sensors window showing all the IRF VR values reported?
Now you should see each particular VR output with a correct label.
Thanks.
RE: Z77X-D3H
Hi stasio,
Thanks.
Thanks for update Martin.
Files attached.
  • STASIO-PC.zip
    STASIO-PC.zip
RE: Z77X-D3H
Is the VCCSA/IMC voltage of 0.993-0.996 V correct?
In that case it would mean the IT8728F VIN4 is the same value monitored ..
RE: Z77X-D3H
In BIOS is on Auto,ET6 show 0.9250V.
IRF for Vdimm also slightly offset (compare with ITE).
ET6 show excatly values set in BIOS and will be nice if you can adjust.
Also,please inform Tamas.
RE: Z77X-D3H
Hm, the SIO has a precision of 12 mV..
When you change the IMC voltage in ET6 is it then reflected by SIO VIN4 and the IRF chip?
RE: Z77X-D3H
IMC set to 0.950V in BIOS.
No change in HWiNFO.
Edit:
It's mean 1.650V,
SIO can show 1.658 or 1.646,right.
RE: Z77X-D3H
Hm, strange.. According to the review the VCCSA/IMC rail should be powered from that IRF.
What else might be that value, any ideas?
RE: Z77X-D3H
Intel HD Graphics?
RE: Z77X-D3H
Is it possible to switch to iGPU only, just for this quick test?
Added +0.01V for Dynamic GFX Core (VAXG DVID) in BIOS.
And value (VCCSA/IMC) change comparing with previous pic.
RE: Z77X-D3H
That's great, now we probably decoded all things here :) Many thanks for the feedback!
Now, interesting would be to check the X79 mobo too ;)
RE: Z77X-D3H
Yea,I just mail to Ray that for X79 I will try to contact my friend.
As said earlier,please inform also Tamas.
Thanks.
Edit:
Instead CPU VID should be CPU V
RE: Z77X-D3H
Thanks :) Please ask your friend for a log+debug file using the latest Beta.
Ray is watching this thread and Tamas probably as well (although he seems to be on vacation currently, I haven't seen him online for few days ;)).
