Z77X-D3H/Z77X-UP5
RE: Z77X-D3H
Probably yes.. It's a bit different, I don't know where it is sourced from exactly.
RE: Z77X-D3H
Thanks.
GA-X79-UD3 debug file attached.
  • X79-UD3-HWiNFO64.zip
RE: Z77X-D3H
Thanks, will adjust for this mobo too. The VRs there seem to be:
1. Vcore = 1.375 V
2. ??? = 1.121 V
3. VTT = 1.051 V
4. DRAM A/B = 1.652 V
5. DRAM C/D = 1.656 V
Do you know what the 2nd one might be (1.121 V) ? Maybe this is the VCCSA/IMC ?
RE: Z77X-D3H
As per GB web page:
Btw,
I will ask my frind.
Here is UD3 voltage control:
http://www.xbitlabs.com/picture/?src=/images/mainboards/gigabyte-ga-x79-ud3/bios10_big.png
Just found that have chipset voltage control also (PCH Core):
http://www.xbitlabs.com/picture/?src=/images/mainboards/gigabyte-ga-x79-ud3/bios12_big.png
Details of X79-UD3:
http://www.xtremesystems.org/forums...eview-LN2-Testing-Guide&p=5081371#post5081371
or better one (UD7):
http://sinhardware.com/index.php/re...abyte-x79-ud7-review-w-3960x?showall=&start=3
RE: Z77X-D3H
Thanks for the additional information.
Problem is, that according to those reviews, the 2nd IR3567 instance should be VCCSA/IMC which seems rather high in case of the dump you attached before (1.121 V).
RE: Z77X-D3H
Ok. Would also be interesting to get dumps from other boards utilizing Digital PWMs, like ASUS Maximus series, etc..
RE: Z77X-D3H
Yes,
confirm is IMC voltage.
  • NtiuH.zip
RE: Z77X-D3H
Thanks! So mystery is solved :)
I'm waiting for some feedback from other machines and will make a new Beta soon. Let me know if you need a new Beta ;)
RE: Z77X-D3H
Can,no problem.
Btw,
latest HWiNFO and SIV dump attached.
  • New Dump Stasio HW-SIV_4.zip
RE: Z77X-D3H
work well on Z77X-D3H.
Now I crossflash my board with Z77X-UD3H BIOS (don't ask me how) and only IR3657 (CPU Vcore) are offset in +.
BIOS in default now,later will increase Vcore.
Rgs,
Stasio
  • HWiNFO64.zip
RE: Z77X-D3H
Thanks for the report. I need more different Vcore values to prove if there's indeed an offset applied.
However, I doubt that on the IRF output an offset is applied, since this is the straight VOUT value.
RE: Z77X-D3H
Set in BIOS Vcore 1.5000V.
Set in BIOS Vcore 1.4000V... OK.
(Set in BIOS Vcore 1.4500V... OK)
(Set in BIOS Vcore 1.4800V... OK)
  • HWiNFO64.zip
RE: Z77X-D3H
Ok,I will try.
Btw,
Set in BIOS Vcore 1.525V... OK.
First I go back to Vcore 1.5000.
1600.........same 6.000
1601..........OK. :)
Solved,thanks Martin.
